TBSS AWD FLT LVL 7 Transmission & YANK PTB 3200
Old Jan 15, 2011 | 12:33 AM
BadMonkey's Avatar
Default TBSS AWD FLT LVL 7 Transmission & YANK PTB 3200
I am changing directions and I might be needing to do something different with my transmission setup. I put this in to support my Procharger and has worked flawless.
I am looking to get $3300 for Both, and will work with you on shipping. If you are in the Dallas area I might be able to work something out for the install as well. I do not want your transmission so you can sell your good one and it will cover a good chunk of this.
Once again, this is for an AWD TBSS.
(This is from FLT's website the transmission I am selling has less then 4000 miles on it.)
FLT Level 7
•300M billet input shaft
•300M billet output shaft
•FLT machined performance pump
•Media blast case, bell housing, and tail housing to restore a new aluminum finish. Prep case for assembly.
•FLT sleeved input drum
•FLT (billet 6061 aluminum) overrun piston
•FLT beast shell kit w/bearing kit
•GM 5 pinion input carrier
•GM 5 pinion reaction carrier
•Bearing style reaction shaft
•New reverse input drum
•Alto wide 2-4 carbon lined band with reinforced anchor
•8 B/W hi-energy clutches w/koleen steels in 3-4 clutch
•Extra Wide Heavy Duty double caged 29 element sprag
•4L65 low roller clutch
•Transgo HD-2 shift kit
•Corvette Servo
•Sonnax super hold 4th servo
•Bushing kit
•New solenoids
•New Internal wire harness ( If needed on 4L70E )
•New GM Spacer plate
•B/W clutches
•Seal & gasket kit
•Filter
•GM deep pan
•Updated aluminum accumulator pistons
•FLT prepped valve body w/ HD 2-3 shift valve modification
•Set end play to FLT specs
•Case cooler fittings
And YANK PTB3200
Let me know. I take PayPal. Time frame would be delivery in 2-4 weeks.
I will split up. Since I want to sell this together, I want 3000 for the transmission and 500 for the converter if I split them up. Otherwise you save if you buy them together. I do not want your transmission, so hell buy both then sell the converter. New this setup would be over 5000 without the core. I am upgrading to a custom 4L80E setup to handle the Twin Turbo's. This is one of the baddest transmissions you can get for the TBSS.
Old Jan 27, 2011 | 02:00 AM
BadMonkey's Avatar
Bringing this back up to the top.
blownss27
Aug 14, 2020 08:27 AM
bighouse
Sep 27, 2015 12:37 AM
chvy=power
Sep 8, 2015 11:06 AM
Bluchevypick
Aug 18, 2015 09:11 AM
