TBSS AWD 4L70E Maximum Performance – Level 7, SFI Flexplate & Vert
Old Oct 11, 2010 | 04:13 PM
Rat Raceway's Avatar
Default TBSS AWD 4L70E Maximum Performance – Level 7, SFI Flexplate & Vert
Well in 2 weeks I will be pulling out my new FLT level 7 470 and new Precision Industries converter. Everything has just been freshed up and has about 2000 miles and 4 dyno pulls. I will be sending it back to FLT for a full inspection and rebuild if needed. So it will be brand new and ship from FLT.
Details...
Precision Industries Vigilante Torque Converter Series
* 9.5" lock-up 4L70E
* Multi- Disc 5 plate
* 3200 RPM
AWD FLT 4L70E Maximum Performance – Level 7
*Deep Aluminum Pan Kit
* Sonnax Super Hold 2nd Servo
* 300M billet input shaft
* 300M billet output shaft
* FLT machined performance pump
* Media blast case, bell housing, and tail housing to restore a new aluminum finish. Prep case for assembly.
* FLT sleeved input drum
* FLT (billet 6061 aluminum) overrun piston
* FLT beast shell kit w/bearing kit
* GM 5 pinion input carrier
* GM 5 pinion reaction carrier
* Bearing style reaction shaft
* New reverse input drum
* Alto wide 2-4 carbon lined band with reinforced anchor
* 8 B/W hi-energy clutches w/koleen steels in 3-4 clutch
* Extra Wide Heavy Duty double caged 29 element sprag
* 4L65 low roller clutch
* Transgo HD-2 shift kit
* Corvette Servo
* Sonnax super hold 4th servo
* Bushing kit
* New solenoids
* New Internal wire harness ( If needed on 4L70E )
* New GM Spacer plate
* B/W clutches
* Seal & gasket kit
* Filter
* GM deep pan
* Updated aluminum accumulator pistons
* FLT prepped valve body w/ HD 2-3 shift valve modification
* Set end play to FLT specs
* Case cooler fittings
I will also be adding in the CAT SFI flexplate as well.
I do not need a core and this makes it nice for someone to keep there stock trans (or sell it) and do the swap with no down time.
This would be about $5400+ (Including a $750 core charge.) To order this setup.
I'm looking for $3900+ shipping and BUYER PAYS PAYPAL FEE'S if paypal is used.
Anyone need a KILLER trans???
Old Oct 12, 2010 | 06:08 PM
Bump TTT!
Old Oct 14, 2010 | 09:05 AM
Bump for the Day! TTT
Old Oct 17, 2010 | 11:37 AM
Open to offers no lowballs!
TTT
Old Oct 17, 2010 | 12:03 PM
RibeiroBJJ's Avatar
Praise The Lowered
Willing to sell just the transmission (no TC or awd tailshaft) and could this trans be used for 2wd with proper tailshaft?? If yes what would you be looking to get?
Old Oct 17, 2010 | 08:16 PM
Sure!
But it not worth trying to make it 2wd. Too much to change from what I have been told...
Thx
Old Oct 21, 2010 | 10:26 AM
Bump! Ttt!
Old Oct 21, 2010 | 03:52 PM
Dirty 30's Avatar
LS1Tech Whore
Wish I had the money.
Old Oct 22, 2010 | 12:15 AM
gmc6.0's Avatar
so this is justt for awd or can it be for rwd truck? if so how much?
Old Oct 22, 2010 | 09:44 AM
This will work for 4wd or awd trucks.
Good upgrade from a 4l60. or a stock 4l70.
Will not work on a 2wd/RWD.
