SLP 1.85 rockers / FREE More Performance valve spring tool
Old Oct 13, 2003 | 09:24 AM
tbyrne's Avatar
Default SLP 1.85 rockers / FREE More Performance valve spring tool
We are offering a FREE More Performance Valve spring compressor with the purchase of any set of SLP 1.85 rockers ($129.99 value!).
"In car" valve spring changes have never been easier for the home hot rodder . Works on C5, F Bodies and all LS1 powered vehicles. The main body is made of billet aluminum and incorporates a steel roller bearing union for ease of operation. This tool is designed to work with any 3/8 hand ratchet, simply add a 3/8 extension for valve springs which are difficult to reach (under cowl). Will work on factory conical valve spring along with aftermarket 1.25" OD spring/retainer sets. For anyone changing camshafts with more than .500 valve lift , this tool is a must! Patent Pending.
The SLP 1.85 rockers will show you results that are similar to doing a small cam change without going into the engine. They fit all of the GM "Gen III" engines (includes the LS1 and LS6 as well the 4.8-, 5.3-, and 6.0-liter truck engines). Their exclusive design is based on the stock rocker and built by the OEM manufacturer, using the same high-quality materials and processes. The 1.85:1 ratio increases lift by approximately 10% over the stock 1.7:1 unit, yielding gains of up to 18 horsepower!
Designed as a bolt-on replacement, these rockers require no valve-cover or cylinder-head modifications to install. You can even reuse your stock pushrods!
This special will be ending on Sunday evening (10/19).
Tom
chopperloco
Jul 10, 2016 10:45 PM
bizle
Jul 22, 2015 07:31 PM
cbhedrick
Jul 20, 2015 10:12 PM
4B11T
Jul 13, 2015 03:48 PM
Mzay
Jul 6, 2015 11:05 PM
