New Brembo 8 piston Gran Turismo Drilled brake kit
Old 11-10-2013, 11:26 PM
04Denali's Avatar
Default New Brembo 8 piston Gran Turismo Drilled brake kit
When you need world-class braking performance that won't overheat, you need a Brembo Gran Turismo Drilled Brake Kit
Everything included for a full brake system rebuild: cross-drilled rotors, brake pads, brake lines, calipers, (missing one 8 piston caliper).
High-performance, for both street and racing uses
Drilled surface keeps brakes clean and fresh; mounting system keeps temperatures low for better handling and lower risk of disc cracking.
includes
two 4 piston calipers, two 355 mm x 32mm 2 piece discs
one 8 piston calipers, two 380mm x 34mm 2 piece discs
stainless steel brake lines
4 Bell tech shocks
THIS IS AN 8587.00 BRAKE KIT NOT INCLUDING SHOCKS
MINUS 1300.00 FOR MISSING FRONT CALIPER, THAT'S A 7287.00 BRAKE KIT BEING SOLD FOR 2500.00 THIS KIT HAS NEVER BEEN USED
Fits 2002-2006 GM
also have custom brackets to fit our quadrasteer rear end for 200.00 dollars
Old 11-11-2013, 01:12 PM
JRENIGAR's Avatar
I say, boy I say "Dayum"!!! Nice setup, Free bump 4 u.
Old 11-11-2013, 06:05 PM
1bad2k's Avatar
That's an awesome kit. If I wasn't pretty close to bsing finished on my z06 swap I would have to consider. Just curious though, what's the story on the missing caliper? I bet that one hurt.
Old 11-11-2013, 06:58 PM
Staggered 02's Avatar
Yes info on missing caliper and how do I go about finding a replacement? Just order through Brembo? Can't be cheap. sigh....
Old 11-11-2013, 07:21 PM
03sierraslt's Avatar
Good to see you around Mark, good luck with your sale.
Old 11-11-2013, 07:44 PM
04Denali's Avatar
Thanks Pat. I know it's been a while. Life gets in the way of things once in a while.
You can get the missing caliper from brembo or any place that sells brembo brake kits. I got the price of 1290.00 from vivid racing.
The front caliper was in my garage during the fire. The rest of the brake kit was in my parts room in the house. Never did find the caliper after the fire :-(
Old 11-15-2013, 12:45 AM
caddy03pimpin's Avatar
Would you sell just the rear kit ?
Old 11-15-2013, 01:17 AM
04Denali's Avatar
I would like to try and sell all together but will keep you in mind if I split them up
Old 11-15-2013, 01:27 AM
Cool thanks
Old 11-15-2013, 10:12 PM
04Denali's Avatar
Price reduced to 3000.00 dollars
Also going to put them on craigslist
Quick Reply: New Brembo 8 piston Gran Turismo Drilled brake kit
