Kicker Audio Upgrade, Amp/DSP, and amplified Subwoofer GM Part # 19303117
GM OEM Kicker Audio upgrade for 2014-2018 trucks without the Bose System
Check for compatibility
NEW PRICE!! $679....SHIPPED in LOWER 48. $640 Local Pickup!!
Local Pickup Available in Houston, TX Metro Area.
Please PM or email. Text to 2 one 4 - 529 - four 279
Thanks!
Kicker's SoundGate PowerStage factory audio upgrade is designed to fit 2014-up GM crew cab pickups without the Bose System. Included with the system are a 10" subwoofer in a custom enclosure, subwoofer amp, multi-channel amp with custom mounting brackets, all the necessary cables to power both amplifiers, and adapter plugs to connect to the factory radio and speakers without cutting into any of the factory wiring.
** This is a used setup - with less than a year installed. The pre-terminated cables to connect the amplifiers to the battery will come with proper under hood connectors to reinstall...See pics."
Don't be fooled by the Subwoofer only kit, this is the complete kit with a plug/play factory amp and DSP processed output. The multi-channel amplifier is rated at 50 watts RMS x 4 channels and powers the front and rear factory speakers. The amp also has a built-in computer-optimized, 32-bit DSP (Digital Signal Processor) programmed specifically for the truck's interior and factory audio system. Custom brackets are bolted to the amp to mount it out of sight, by the steering column. The included wiring harness has adapter plugs that connect between the factory radio and factory harness, so cutting/splicing/testing the existing wires is not necessary. The included power harness is connected to an accessory lug in the engine compartment, and specific wire routing instructions are included.
Subwoofer: The single 10" Kicker subwoofer is loaded in a custom enclosure and powered by a 200-watt amplifier mounted to the enclosure. The included wiring harness has an adapter plug that connects to the multi-channel amp's harness (for subwoofer signal input) and the power cable is connected to the accessory lug in the engine compartment. Specific wire routing instructions are included. The subwoofer is mounted under the rear seat on the passenger's side. Electrical System: Both amplifiers are designed to have minimum impact on the truck's charging system. Dimensions: Amplifier: Width: 8-1/4" Height: 1-3/8" Depth: 6" Subwoofer Enclosure: Width: 19" Height: 8" Depth: 17-1/2"
