FS: Richmond ROD 6 Speed Transmission
Old Jun 21, 2012 | 05:32 PM
BMEP123's Avatar
Default SOLD FS: Richmond ROD 6 Speed Transmission
For Sale:
Richmond 7051626 AA ROD 6 speed manual transmission.
I purchased it used 3 years ago for a project that's not going to happen.
It appears in very good condition, includes the shifter.
I've spun it around and shifted the gears and suspect it's fine.
I was planning to put it into a Chevy 1/2 ton. The gear ratios are perfect just leaving the stock 3.73 rear gears. And reverse is an extra deep 4.79:1, great for trucks. With 3.73 gears and this trans it will give about the same overall gear ratios as a T-56 with 4.88 gears. Staying with the 3.73 gears keeps the driveshaft RPM down below the critical speed so you can run the truck up to 140+ mph without spitting out the driveshaft.
It's the T-5 version with longer tail shaft, so, it's about the same as a T-56 in length, which is why I chose this one. Either the trans or the shifter will need to be rotated 17 degrees to get the shifter straight up.
Ratios:
1st 3.28
2nd 2.13
3rd 1.57
4th 1.24
5th 1.00
6th 0.76
$1750
Call Jim at 612-360-5803
http://minneapolis.craigslist.org/da...095158521.html
Old Jun 28, 2012 | 03:56 PM
BMEP123's Avatar
SOLD
$1750 SHIPPED
It's going on E-Bay tonight
Oobray
Jun 13, 2022 03:38 AM
5.3Okasai
Mar 9, 2022 01:07 PM
thewrx
Aug 12, 2015 08:28 PM
Ammadien
Jul 22, 2015 08:50 PM
