Edge Evolution 25500 "RACE" DPF Delete
Old Mar 29, 2015 | 08:34 AM
rockertype's Avatar
Thumbs up Edge Evolution 25500 "RACE" DPF Delete
This is the 25500 "RACE" model Evolution from my 2010 LMM. It is in perfect condition and worked excellent on my truck! This tuner was returned to stock before it was removed. It also includes the "HOT UNLOCK" code from Edge. It comes in it's original packaging with OBDII cable, USB download cable, instruction manual, Fusion CD and factory mounting bracket. This tuner is absolutely perfect! I'm asking 600.00 for everything shown.
This "RACE" model has 7 power levels. And can read and clear codes. It can also recalibrate your speedometer for different size tires or gear ratios. This is the Edge tuner you want if you are planning to DELETE your DPF!
On LMM's the EGR codes are disabled on levels 1-3. The EGR is disabled on levels 4-7. Disabling the speed limiter on LMM's is preprogrammed in the calibrations on levels 3-7.
Chewy07
Nov 14, 2015 09:46 PM
Glenn98ZM6
Sep 18, 2015 07:31 PM
OVOAustin
Sep 15, 2015 08:32 PM
chvy=power
Sep 8, 2015 11:06 AM
