Crank with bearings, Cnc heads, 60lb injectors, JE pistons lq4 rods
Stock lq4 crank, king bearings crank and rod, balanced, turned .010 main and .020 rod Came from engine that spun bearing crank is ready to install and keyed. $350
Cnc ported 317's from LPE (ligenfelter) complete with valves and springs $450 60lb Siemens p/n107961 was told they've been flow matched and have 2000 miles acquired them from a trade $300 Forged JE pistons and wrist pins stock 6.0 bore removed at 60k also cam from engine that spun bearing no rings or wrist pin clips $300 Lq4 rods $75 all 8 + 2 ls2 rods ***Looking for shorty injectors for my magnacharger set up, ls7 springs or better, hp tuners pro, fuel pump set up.*** |
what #s are the heads? 317's ?
Yes sorry... Fixed it
Pm sent
can you give some more insite on the pistons
Pistons stock bore stock stroke they are flat tops with a small recess down. Pm me I'll send you pics
interested in the injectors but would have to have by friday. i am in NC. please pm me ur #
Do you have any more info on the heads? I never knew LPE ported heads.
I have the build sheet for them pm me your number I'll share it with you. The heads and block are stamped with a LPE serial number.
Original buyer backed out... Everything is back available.
