Complete Aeromotive Eliminator Fuel System
Old Mar 11, 2017 | 05:27 PM
CooperS7777's Avatar
Default Complete Aeromotive Eliminator Fuel System
This is a complete return style fuel system setup; it has everything you need to install and run this system on a TBSS, minus simple wiring.
Aeromotive Eliminator in tank pump, Aeromotive billet pump controller, Aeromotive filter, Fuel Lab FPR and Aeroquip Starlite lines. The lines are setup to feed a full return system with ~15' between the pump and FPR. I used the stock tank with a port drilled for the Eliminator pump.
The setup runs -10 line between the pump and filter, drops to -8 at the filter outlet and drops again to -6 at the Y before rail feeds. Return side is -6.
$1200 for the whole get up.
