Circle D 4L80E Pro Series Multi Disk Torque Converter
Old Feb 11, 2016 | 02:03 PM
Ferocity02's Avatar
Default Circle D 4L80E Pro Series Billet Multi Disk Torque Converter
I am selling my Circle D 258mm Billet Pro Series Multi Disk Torque Converter for 4L80E. I used it in my Silverado for roughly 3k miles before buying something for fuel-efficient and parting out the truck. The converter is for a 4L80E transmission but uses a 4L60E front, meaning you can use a 4L60E flexplate. This is a common setup and aftermarket 4L60E flexplates are far more common/cheaper.
The converter is currently at Circle D getting the hub replaced because it has unusual wear on it (due to a bad pump bushing install in the 4L80E). Since they are opening it, they will also be doing a full inspection, cleaning, and can re-stall at no extra charge. Therefore, you get to select the stall speed. You can see what they offer online (see link below) or call and they can recommend a custom stall speed for your application.
In conclusion, you're getting an essentially new badass converter with any stall speed you would like. From Circle D you would pay about $1260 shipped. I am asking $1071 shipped (15% off)
Please PM me with any questions.
Circle D Specialties Pro Stage III 258mm Multi Disk Torque Converter For GM 4L80 Transmission
These pictures are from before it was sent to Circle D:
Old Feb 13, 2016 | 09:55 AM
Ferocity02's Avatar
Bump!
Old Feb 18, 2016 | 12:54 PM
Ferocity02's Avatar
Bump for a basically new converter as whatever stall speed you want.
Old Feb 22, 2016 | 12:28 PM
Ferocity02's Avatar
Bump!
!Hostile!
Jan 29, 2016 05:07 PM
Go5.3tt06
Jan 14, 2016 11:41 PM
aksz71
Jan 14, 2016 06:55 PM
redz71truck
Jan 14, 2016 11:46 AM
LT-1 SS
Jan 13, 2016 06:53 AM
