BNIB open box lq4 and lq9 pistons
Old Aug 17, 2017 | 01:54 PM
RPMSpeed Tech's Avatar
Truck Sponsor
Default BNIB open box lq4 and lq9 pistons
Open box pistons and 1 ring set
First set is lq4 pistons. stock bore. stock dish. hyper e. uses stock rod. floatin pin piston set with locks and pins will work with gen3 pressed rods or gen4 floating rods. coated skirt. $200 shipped
Second set are flat top lq9 flat tops. stock bore. stock flat top WITH hard anodized coating and coated skirt. works with gen3 pressed pin or gen4 floating rods. $210 shipped
Rings are for 4.000 bore. std fit. steel top moly coated steel second std tension oil. works with stock pistons or the above mentioned pistons. $75 shipped.
Lq9 pistons
Lq4 pistons
Old Aug 19, 2017 | 10:31 AM
MrHorsepowerLSx's Avatar
11 Second Club
Just to help others, I needed 1x lq9 piston a few years ago and ordered it though the dealership. When it says "stock" my factory piston was 5mm oversized so roughly 4.020" bore. The dealer accidentally ordered me the wrong piston. Just measure your current bore/piston size before ordering
Old Aug 19, 2017 | 11:23 AM
Truck Sponsor
These were returned by customers that decided to go 4.030. They are 4.000 bore.
