Zex nitrous not working???
Installed my used nitrous system tonight it was suppose to be in good working condition but im not sure. Ran all wires lights came on and it appeared to be working. Pressed the reset button and held my throttle still seemed to be working light was going from red to green to none. turned it off then back on pushed the throttle but the sylinoid wasn't clicking is there a way to fix this or am I screwed? Any help will be appreciated
thanks William
thanks William
First, I know nothing of the ZEX nitrous kits. I have never used or installed one.
Don't they use the O2 sensors as a saftey device. Maybe the vehicle has to be running and running rich to activate the soleniod. Also check you grounds and wiring.
nitrous
the directions say to just have the key on and I should be able to hear the noids clicking. I ran a ground to the battery then a hot to the switch inside and to the batttery.
thanks William
thanks William
Formerly one92rs
im sure you have this---
http://www.zex.com/Technical/Instruc...stallation.pdf
i would make sure you have the correct tps wire. then i would recheck the ground.
I still have power to the box and I have been through the learn system several times and it appears to be working correctly just no selnoids clicking??? where would I find out what color my tps wire needs to be I have an alligator clamp on my blue one is this correct??? I have no volt gauge or I would check
thanks William
thanks William
Formerly one92rs
yes the blue wire is correct. it should read about 4.40 to 4.50 volts at wot. i would make sure that connection is good to.if you have a way to put at least 6 volts and no more to that wire i would try that to see. as long as the all the connections are good it should work.
how do you like your Nelson tune and what is the final cost on one?? I have no way to check my voltage tonight maybe I will be able to get to it tomorrow. Really hoping I can get this going by Saturday I want to take it to the track and get some numbers
