Z06 in SCSB ?
i was wondering what it would take to put a Z06 in a SCSB. i know i would have to change PCM .... what else would i have to get or make it fit.... is there neone that knows someone that has done that or knows what i would have to do to make it work.... thanks
11 Second Club
you can run the LS6 intake and accessories or the truck intake accessories, take your pick. If you have just a long block the cheapest way would be to run the truck accessories and intake. The truck PCM and harness will work just fine with the LS6. You will have to tune it though, it obviously won't run its best with the truck programming.
to put a Z06 into a silverado would take quite a bit of work. i mean you can't just drop a corvette in the bed
now putting an LS6 into a truck is a little easier
How did I know that was coming? Leave it to Crazy
GM Performance Parts sells two ls6's. One is a short block at/about $5,000.oo and comes with F and Y body oil pan. The other is a long block and comes with coil packs, manifolds (intake and exhaust), injection system, every thing but the acc and is just shy of $6,000.oo. You can sell the stuff you dont need to get some of your cash back. I think the long block will be cheaper over all.
