Z06 heads and cam in LQ4 HD silverado? '05
Old Oct 3, 2005 | 09:22 PM
pacebria's Avatar
Default Z06 heads and cam in LQ4 HD silverado? '05
Would this combo work good on a truck?
Old Oct 3, 2005 | 11:52 PM
desTRUCKtive's Avatar
it depends what you want to do with it. It would work great if you just want to race and have a RC. But the ZO6 heads will raise your compression quite a bit. I would think that you would be running near an 11.0 compression ratio, which I think is to much for an HD truck and to much if you tow.... you can run into some Knock retard issues with a compression ratio that high on a truck.
Old Oct 4, 2005 | 12:00 AM
99Silver6.0's Avatar
Id say more like 10.5:1 with the 62cc chamber of the LS6 heads. You can put a fatter gasket in if you want also. To lower CR a tad. They are good heads. Big runners, good flow, light sodium filled valves.
5.3Okasai
Mar 9, 2022 01:07 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
steves86ta
Jul 28, 2015 10:21 AM
Offroadunleashed
Jul 20, 2015 02:25 PM
NuckenFuts
Jul 9, 2015 08:45 AM
