XR265HR in a 5.3 dyno graph and thoughts
Old Apr 4, 2009 | 02:32 PM
  #61
agreif's Avatar
Originally Posted by NicD
I am running 7.40 hardened pushrods and 918s even though the valve springs are kind of overkill for such a small cam.
Are those the adjustable rods or the 7.4 replacements without adjustment?
Old Apr 4, 2009 | 02:50 PM
  #62
budhayes3's Avatar
PT's Slowest Truck
An adjustable pushrod is just for checking for pushrod length, you would use adjustable rockers to fine tune valvetrain clearance/valve lash
Old Apr 4, 2009 | 05:08 PM
  #63
agreif's Avatar
See, I try to act like I know what I'm talking about and this happens. I thought there was some adjustable pushrod. Thanks for edjumacating me Billy. I'm guessing I should just go with Comp's pushrods, Comp PART #7955-16.
Old Apr 4, 2009 | 06:51 PM
  #64
budhayes3's Avatar
PT's Slowest Truck
Whatcha buildin? Getting a new camshaft?
Old Apr 4, 2009 | 06:55 PM
  #65
agreif's Avatar
Nahh, never upgraded the stockers with the new camshaft and figure it's probably not a bad idea, especially if I ever thrown on a charger or laughing gas.
Old Apr 4, 2009 | 07:20 PM
  #66
budhayes3's Avatar
PT's Slowest Truck
Gotcha, you have the right part number, 7955-16
Old Apr 6, 2009 | 04:29 PM
  #67
NicD's Avatar
9 Second Club
Originally Posted by jiar577
NicD, I installed the same cam on my '06 5.3 over the weekend. You told me before you set your shift points at 6300rpms, is that for all the gears?
Also, I've read mixed comments on removing the cats, some say removing them hurt lowend. Did you removed them? I'd love to see real info on cats vs no cats on the lowend.
Thanks
Yes, I set a 6300 rpm shift point for all gears.
I didn't do any back to back tests with and without cats on my truck but I have never seen a loss of low end on any car by removing the cats.
Old Apr 6, 2009 | 07:25 PM
  #68
006rcsb's Avatar
how well would this cam work with a blower or turbo setup?
Old Apr 7, 2009 | 04:58 PM
  #69
NicD's Avatar
9 Second Club
I think it would work as well as any other mild cam. The powerband is nice and really brings up the top RPM area to be on a level playing field with the torque so it would be a good balance IMO for a turbo or blower. It doesn't have a ton of overlap either.
Old Apr 10, 2009 | 10:21 AM
  #70
Ronco's Avatar
From: Outside of Birmingham, the only one that counts
NicD,
Tell me about your intake. I have an "01 CCSB HD 4X4 6.0 that curbs right above 6000# and I cannot lose any bottom end even with 4.10's and stock 31 inch tires.
Can you point me to good information to help me learn more about the LS intake and their characteristics?
Thanks in Advance,
Ronnie
