Is it worth going 78 to 90mm TB?
Old Nov 9, 2016 | 05:04 PM
2002_Z28_Six_Speed's Avatar
I am not sure you would see the actual, full vacuum while monitoring the PCM. Doesn't the PCM have a function that tries to scale the MAP signal for altitude. Might be a job for a dedicated vacuum gauge.
Old Nov 9, 2016 | 10:21 PM
Fast355's Avatar
Just read the MAP at Key-ON and again at WOT. IIRC it is about 3 kpa per inch/hg of vacuum.
Old Nov 10, 2016 | 11:37 AM
Vortec350ss's Avatar
What I am saying is as you scan when an intake part of too restrictive you see vacuum in upper RPM ranges. You see KPA fall off. Here at sea level it is sometimes as low as 94-95kpa or worse up near shift points. Obviously uncorking that is worth good power.
