Will a stock fan shroud work with a 34" radiator?
Old Jul 12, 2006 | 02:34 PM
thunder550's Avatar
High on diesel fumes
Default Will a stock fan shroud work with a 34" radiator?
I'm tired of having to keep a close eye on my ECT's when towing, and I keep burning out relays in my fan harness, so I'm thinking about going back to a clutch fan. Am I going to have to change back to a 27" radiator or will the 34" one work?
Old Jul 12, 2006 | 02:37 PM
TIM Z's Avatar
11 sec. Truck Mod
i dont see why it wouldnt, you could always double check the part # with one from a 6.0 truck with a clutch fan and shroud. i'd bet there the same.
Old Jul 12, 2006 | 02:39 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
you have to have two extra bolts like the ones that are holding the radiator in to the core support, the bottom of the fan shroud will just drop right in to the groove at the bottom of the radiator.
Old Jul 12, 2006 | 02:41 PM
thunder550's Avatar
So there are no tabs on the sides on the shroud? That is what I was concerned about.
Old Jul 12, 2006 | 02:57 PM
1slow01Z71's Avatar
I would just use some bolts with aircraft nuts with washers to go through where the push pins go and call it good. Either that or see if you can track down a fan shroud out of an HD truck.
Old Jul 12, 2006 | 02:58 PM
thunder550's Avatar
Will do
Thanks!
Old Jul 28, 2006 | 11:04 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I still have my stock radiator. I dont know if its a 34" or not. My truck runs right at 200*. I see most posting temps in the 180-190's. Do you measure straight across or diagonal? Trying to figure out how to cool it down a little. Stock T-stat as well.
Old Jul 28, 2006 | 11:06 PM
1slow01Z71's Avatar
160* stat ought to cure it
Old Jul 28, 2006 | 11:11 PM
desTRUCKtive's Avatar
Hell no that stat wont cure it. I am in the same situation and I was talking to Todd (vanilla gorilla) and he said that he is having the same problem in the heat.
Why dont you keep the 34" and if you have to buy a fan shroud for the 34" But I think that the stock one should work.
Old Jul 28, 2006 | 11:14 PM
1slow01Z71's Avatar
Then why did my temps drop from 210ish down to 170-180ish?
