wierd MAF readings??
the maf reading goes up with rpm but at about 5400 rpm it goes from around 42 to -42 and stays negative until the shift. what in the hell could that be? all the other readings look fine. i thought it was just the whipple piggyback computer doing this but i removed it and swapped injectors yesterday and it still does it.
all other readings stay the same. when the maf goes negative i can't tell a difference but i thought it was really wierd and could cause a problem.
