Wideband sensor
Old Oct 7, 2007 | 07:54 AM
moog5050's Avatar
Default Wideband sensor
I was planning on installing a wideband today for later tuning. Rather than replacing the o2 sensor, I was going to weld in another bung to screw in the wideband sensor. I read that it should be installed at least 24" downstream from the block, but before the cat. I have dynatech LTs with cats. Does this mean I should be welding the bung on the header right before it bolts to the cat? Would it be a problem if I just install after the cat? I have read others do that, but does the cat alter the reading? Thanks for your help.
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
Wrecker 426
Sep 30, 2015 09:39 PM
WICK3DxGATA
Sep 24, 2015 06:56 PM
