Why will it eat the tires off
Old Oct 10, 2010 | 12:58 PM
2004SSS's Avatar
from a dead stop ? could it be an open diff and your spinning on one side and the other your not?
Old Oct 10, 2010 | 05:43 PM
silverado2000's Avatar
im guessing its pulling timing, dose it feel good up top? and if its shifting all around you can usually tell.
Old Oct 10, 2010 | 08:45 PM
3DTIM's Avatar
It has a locker under it.
Pulls good after it get going. Shift are fine.
Old Oct 11, 2010 | 02:38 AM
well we need alittle more info, when did all this start after you changed something? or just one day while you were driving?
Old Oct 11, 2010 | 08:22 AM
TIM Z's Avatar
11 sec. Truck Mod
You really need a LIVE Tune. I bet your tune is Def. on the conservative side.
No Knock on the tuner, but mail order tunes are usually on the safe side.
Get a Live tune and i bet she comes to life.
Old Oct 11, 2010 | 08:43 AM
3DTIM's Avatar
Would be nice to get a live tune but no one around here that dose them. Did some testing with it yesterday and looks like it will do it if the truck sets off for 30-40min. Much longer than that and it is fine or if driving you just stop and get after it it is fine.
Old Oct 11, 2010 | 08:47 AM
TIM Z's Avatar
11 sec. Truck Mod
I would drive somewhere and have it done, its worth it and the power you gain just mike make your towing abilities better!!
PM me if i can help ya!
Old Oct 11, 2010 | 09:39 AM
tiffo60's Avatar
Sounds like a heat issue to me, possible inter-cooler coolant getting hot after the first pull and not cooling down quick enough before you do another run, you can probably pop the hood after a hard one and see if the fluid is boiling... Do you have anyway to monitor air temperatures after the blower?
Old Oct 11, 2010 | 06:26 PM
3DTIM's Avatar
No and just how do you do that?
Old Oct 11, 2010 | 07:46 PM
tiffo60's Avatar
Lightnings have a IAT sensor under the intercooler to monitor intercool efficiency post blower. I would think you could/should do the same on the chevys
