Why do you supercharge?
My question is <<zipping up flame suit>> Why are folks so fast to drop 5 grand on radix kit to gain 150 horsies when you can go buy yourself an entire 408 for the same money and put down the same horsepower? I would assume the 408 will also be less stressed and longer life motor than a 4.8 or 5.3 running with 8 lbs of boost. I'm not trying to turn this into a pissing match, but I am curious why so many folks supercharge rather than do an entire motor swap? I just don't see any benefits yet of supercharging.......
Joe
Joe
Originally Posted by David Cairns
1) Supercharging is easier to do than swapping a whole engine out.
2) A supercharged engine gets better mileage than a bigger engine.
3) Superchargers look cool
That sums it up in a nut shell.
Some people do not, or can not take the time to do a complete motor swap. Honestly, you may be able to get a motor for 5 gs...but there is alot more involved than buying a motor and dropping it in. The Radix will take you approx 8 hours to install start to finish, a motor swap (done right) is alot more than that......Then lets talk about tuning the larger motor....if you dont know how....then what, pay someone.
Radix $5150 Suggested Retail and you are done
Big Motor $5000 +
I know there are some good engine builders out there, dont get me wrong. But if you are looking for a true BOLT on and GO system that will give you 120 RWHP with 18 mpg....then you know where to go!
Basically the supercharger makes a little motor think it is BIG.
i agree with david. but if i had the extra 5000 to spend i think i would go with the 408. and count my pennies till i could charge it. either one you choose your gonna need tranny work to hold up.
Originally Posted by whitt1
$5000 is really on the low side for a 408 with decent heads and a cam.$6500 to $7000 is closer to the truth.
After putting the Radix on the H2 I don't see how I could possibly put a whole engine in. Those side fenders are seriously tall. I think I would have to take the tires off and put it down on blocks to get a hoisted engine over the fenders.
At any rate, you just don't pull a low mileage engine for no reason. The Radix was the obvious choice.
Cory
Cory
