Why did my fuel pressure go up?
Old Jun 2, 2006 | 01:43 PM
thunder550's Avatar
High on diesel fumes
Thanks, I will check all that out. Yes, I pulled the motor/tranny/t-case out together, so I suppose it's possible that something got pinched.
It's an electric gauge. I'll try to find a mechanical one to hook up to make sure. Thanks for the ideas
Old Jun 2, 2006 | 01:51 PM
dewmanshu's Avatar
Moderately Differentiated
No prob...I had a horrible time with mine as well. I put a shielded wire in for the sender and grounded the shield on one end and that solved my problems. Not that is your problem, but don't forget to check the simple things as well. Good luck!
Old Jun 2, 2006 | 02:41 PM
RoninsDenali's Avatar
Originally Posted by thunder550
How could that happen? If everything is going through the filter......and if it did happen, how would I fix it? New return line? Is there some kind of additive I can run through a tank of gas to clean things out?
Although others have pointed it out i'll post anyway
Big culprits for this would be, the flex line at the engine fuel rail, and the flex lines between the tank sender and the steel lines. This is probably you're problem, that you just got a little kink in there somewhere when doing your engine/tranny pull.
Old Jun 3, 2006 | 03:11 PM
thunder550's Avatar
Pulled the line off the FPR and the pressure shot up to 64 psi, put it back on, back down to 58. I'm gonna re-check all the lines and make sure one isn't leaking, then I'll check the return line and see if it is kinked.
Old Jun 4, 2006 | 04:48 PM
thunder550's Avatar
Well I pulled the s/c off last night for a different issue, and when I reinstalled it the pressure was back to normal, so there must have been a small leak in one of the hoses somewhere.
Old Jun 4, 2006 | 05:53 PM
dewmanshu's Avatar
hmmm...small leak in which hose, the fuel hose?
Old Jun 5, 2006 | 12:26 AM
thunder550's Avatar
No one of the vacuum hoses
Mossyoakglock
Aug 28, 2015 12:49 PM
noproblems209
Aug 10, 2015 06:57 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
