Who's running meth in a N/A motor?
Old 04-05-2012, 04:40 PM
oakley6575's Avatar
Well I would run a 50/50 mix water and methanol. Increase the timing from around 3000rpm to 6400rpm. Wouldn't it help out a lot in the summer time?
Old 04-05-2012, 04:42 PM
nonnieselman's Avatar
In theory it should.
But why 50/50 mix? So it would cool more and not as much fuel?
When i had the rear mount turbo, i started out running -30* WWF with 25% VP1,, try buying that stuff here in MS where it gets down to 30* sometimes, had to get my guy to order me a case.. He knew not to ask.
After towing alot with it, i went to straight VP1 and tuned it from there,, IATs dropped fast.
Old 04-05-2012, 04:43 PM
Mod with training wheels
smokeshow's Avatar
Its for the compression increase. Adding water to the combustion also increases knock resistance when done right.
Old 04-05-2012, 04:45 PM
hum... ill try and mix it to see what happens.
Dunno how im goin to get it to work tho... lowest my box will go is 2psi.
Old 04-05-2012, 04:48 PM
oakley6575's Avatar
What box?
Old 04-05-2012, 04:49 PM
The control box for the meth.
Old 04-05-2012, 04:50 PM
Progressive Water Alcohol Controller
Old 04-05-2012, 04:52 PM
oakley6575's Avatar
The snow kit I was looking at buying has a vacuum controller box. So it progressively injects more water/meth based on manifold vacuum.
Old 04-05-2012, 04:56 PM
yikes
$500
Quick Reply: Who's running meth in a N/A motor?
