Who sells 160 thermostat for Truck?
Old 10-15-2004, 04:45 PM
jboomer's Avatar
well mine came with the housing. i think that the difference.
Old 10-15-2004, 04:54 PM
PT's Slowest Truck
budhayes3's Avatar
Originally Posted by Naked AV
Someone on another forum is saying that the Hypertechs do not work properly. Does anyone know anything about this supposed issue?
I'd like to know about this too...I recently installed a Hypertech 180* stat, and didnt' really notice any change in coolant temp from stock. With the scanner, my temps are actually more inconsistent, ranging from 188* to 197*. With the factory 195* stat, it was pretty constant 195*-197*, sometimes going slightly over 200 to 203* after beating on it. One thing to consider though, the weather has gotten cooler too, which may have something to do with it.
Old 10-15-2004, 04:56 PM
2MuchRiceMakesMeSick's Avatar
www.thunderracing.com
Old 10-15-2004, 07:44 PM
eallanboggs's Avatar
The thermostat changed on the trucks for 2004. I believe the 2003 still have the old style that come with the integral housing which you can modify yourself. You can't mod the 2004 thermostat because they are stamped (crimped) together. You can't take them apart with a quarter turn like you can on the old style but, they are cheaper because you retain the thermostat housing and just change the thermostat itself like the older chevy small block type thermostat. I got mine from Lingenfelter. It still cost $30 with shipping but, nothing on an LS1 is cheap. I tested this one on the stove too. It opens just over 160 F. I put it in and now my water temp stays at 185 F as long as the truck is moving. Once I get in stop and go traffic the temp slowly creaps up to about 195 F and then drops back down as soon as I hit highway speeds again. It has not hit the former running temp of 205 F since I installed the 160 F stat. I also installed one of the oil cooler adapters that come on the 6 liter truck so I could put in an oil cooler so that proably helps lower the overall temperature a bit as well.
ZONES89RS
21
09-24-2015 05:58 PM
wrb002
08-31-2015 12:00 PM
jmarkway
07-18-2015 09:23 PM
black6spdz
07-16-2015 01:32 AM
GM1697
07-14-2015 01:21 PM
Quick Reply: Who sells 160 thermostat for Truck?
