Who runs a 222/224 .566/.568 112
Old Nov 15, 2006 | 05:44 PM
ramdaspadhye's Avatar
Originally Posted by Ruffrider5.3
Go big the first time or do over when your not happy........
And this is coming from someone who doesn't have a cam? At least your sig doesn't say you do...
"Big" is like saying "normal." Can you say vague? Guy was right when he said the 275 cam was too big for a heavy SUV. I need something with a shorter duration in order to keep the low end since it's gonna be mostly a low-mid cam.
Old Nov 15, 2006 | 06:06 PM
jakebdb56's Avatar
he's got one, just look on page one.
you could go with the old man truck cam from thunder racing, it has good specs for a yukon IMO.
214/220 .600/.523 115 LSA +2 is the specs on the old man truck cam. it's got some good lift, and the duration isn't much. plus you dont "have" to tune for the cam, but it's always best if you do.
-13* of overlap won't be real choppy either.
Old Nov 15, 2006 | 07:26 PM
You have a clip of this idling?
Old Nov 15, 2006 | 07:40 PM
I am runnig that cam on my truck it is a great strong cam for my reg cab truck with the 5.3L fully bolt on, tuned, that cam loves nitrous alot i tell you my truck loves it. Well for your Yukon get a 220/220 with a 112 or 110 Lobe separation thats whats going in om my cousin fully bolt on Tahoe in two weeks
Old Nov 15, 2006 | 08:13 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I had a 210/218 .551 112lsa in my 5.3. Its actually in the 6L now. Sound clip of the 6L in my sig. The extra cubes eat up the lope but it actually didnt lope very much in the 5.3. Might need to go to a 110lsa to get what you're looking for with a 210/218 duration. The low end tq on my cam is great.
Old Nov 15, 2006 | 09:15 PM
With those specs, it should lope pretty good you'd think with the duration and lsa. Do they make a cam wtih the same config and 110?
Also, the XR265HR is similar to yours. It's 212/218 .522/.529 114. That be a decent low to midrange booster? I'm planning on upgrading the stall to AT LEAST 2500, probably 2800-3000.
Old Nov 15, 2006 | 10:30 PM
SOrry for acting like an *** in the last post...just had a really long day
Old Nov 15, 2006 | 10:40 PM
1SlowHoe's Avatar
You would think. It also has 52* of overlap which is really where the lope come from. But still, not very much lope?? I dunno. It bleeds off boost as well so if you plan to get boosted then a lopey cam is not whay you want. When I swap the GT2-3 in, I will make you a deal on the 210/218. But who knows when I'll get around to that.
The cam your looking at would work well. But not lope. You want to keep your power band low because
1. Your weight
2. Youre not going to be spinning the motor over 6K rpm anyway (are you?) I shift at 6200 because my cam quits pulling at 5800-6000.
Old Nov 15, 2006 | 10:50 PM
1SlowHoe's Avatar
My cam sounded like this before I tuned it. Stock 550rpm idle, 6L. Stock exhaust with single magnaflow muffler.
Old Nov 16, 2006 | 12:27 AM
jakebdb56's Avatar
sounds nice. I bet it sounded better @ WOT
