who has built up the 4l60E
Old Feb 21, 2003 | 02:17 PM
Yelo's Avatar
Default Re: who has built up the 4l60E
Just yank out the 4L60 and stuff in the 4L80...they are the same size and they are interchangeable...the computer won't care which one is in there.
As for the gearing...
Gear....4L60.....4L80
1st.....3.08.....2.48
2nd.....1.62.....1.48
3rd.....1.00.....1.00
4th.....0.70.....0.75
so to get the same acceleration performance you would have to go ftom a 3.42 rear gear to a 4.10 rear gear...which is always a good thing no matter which tranny you have
<small>[ February 21, 2003, 02:20 PM: Message edited by: Yelo ]</small>
Old Feb 21, 2003 | 02:18 PM
Seeing Red Again's Avatar
Click Here to compare the gear ratios of the 4l60, 4l80e, and the th-400.
Old Feb 21, 2003 | 02:40 PM
redaddiction's Avatar
where is the cheapest place to get one? i might be interested when i blow my tranny again
marc
also are convertors interchangable with the 80 and 60?
Old Feb 21, 2003 | 02:53 PM
Yelo's Avatar
my personal choice would be to buy one direct from GM...you get the factory warranty
The price is about $1700-$1850 depending on where you get it from though
as for the 4L65-E....it's not a bad tranny...just based upon the old 700R4 like every other 4L6* series....stick with the heavy duty 4L80....you'll thank yourself in the long run
Old Feb 21, 2003 | 02:57 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by redaddiction:
<strong> where is the cheapest place to get one? i might be interested when i blow my tranny again
marc
also are convertors interchangable with the 80 and 60? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I can get you the hook up...No the converters aren't interchangable.
Old Feb 21, 2003 | 03:19 PM
creederado's Avatar
The 4l80e is interchangable w/the 4l60e? No driveshaft shortening or crossmember moving?
I would buy a 4l80e and upgade to 4:10's before trying to make the stock one stonger.
With all the mods for the engine why is buying aftermarket Tranny stuff so risky? I have heard bad things about Jet, not much about B&M or Hughes. WTF? For the 4l80e In order to get the factory warranty do you have to have it installed buy a Chevy dealer? <img border="0" alt="[bomb]" title="" src="graemlins/gr_bomb.gif" />
Old Feb 21, 2003 | 03:54 PM
Yelo's Avatar
You DO need to use the 4L80 crossmember...which you CAN purchase...or fab a tubular one....the holes are already in the frame for the crossmember, the 4L80 is 3/4" shorter than the 4L60 but the holes for the T-case mount holes (if you have one) are elongated to accept the shorter tranny..the driveshaft slip yoke depth will make up the difference between the two transmissions without a problem....I have seen this conversion done, it took about 4 hours of shop time to do it and the guy drove in and drove out
Old Feb 21, 2003 | 04:33 PM
red53gmc's Avatar
Everything I've heard says the 4L80E is a bigger transmission than the 4L60E and there may be problems putting the 4L80E into a regular 1500 truck.
Old Feb 21, 2003 | 04:38 PM
Banned
mix, what kind of hook up are we talking about here? what are you running in your ride? my tranny is slippin like hell now so i think it's getting close to time for a new one that can handle some torque. it's weird how i never had any trouble until i ran n2o through it. weird...
Matt
Old Feb 21, 2003 | 06:24 PM
ok so just change the crossmember and thats it becsause that sound to good to be true if you ask me but hey i could be wrong but remember i have a short bed and regular cab are we sure about this because i will get one when my tranny goes out again
marc
