Wheres that sound from!
Old Dec 29, 2009 | 01:21 PM
supercharged680's Avatar
Angry Wheres that sound from!
hey there guys... theres this wierd noise when i boot the throttle.. like a tick tick tick sound.. i could hear the sound the first few days after the vararam and tune.. after a few days of going full throttle the sound disapeared what could be the sound from does it affect my engine in anyway? should i check the tune or something.. im really worried because my car is still brand new with 3000km on the odo..
best regards
Old Dec 29, 2009 | 01:30 PM
00ChevyScott's Avatar
Wearin' da big hat
Sounds like you're getting preignition (engine ping). What octane gas are you running and who tuned it?
Old Dec 29, 2009 | 01:44 PM
98 octane.. a good tuner my country.. united arab emirates
Old Dec 29, 2009 | 01:47 PM
Wearin' da big hat
Tell him the problems you're having, and I wouldn't put that motor under anymore stress until you fix the problem.
Sounds like you need your tune adjusted to me.
Old Dec 29, 2009 | 01:49 PM
do u think my engine is affected already? :S what does this pre ignition result in?
Old Dec 29, 2009 | 01:51 PM
SILVERADO11's Avatar
Originally Posted by 00chevyscott
sounds like you're getting preignition (engine ping). What octane gas are you running and who tuned it?
im with you, sounds like preignition, make sure you fill up at the same station and same octane fuel that you ran when you had it tuned, if that dosent help you may need a retune.
Old Dec 29, 2009 | 01:57 PM
do u think my engine is affected already? :s what does this pre ignition result in?
it should be fine, my truck pings alot during the summer, i just stay out of the throttle when ever i hear the slightest bit of ping, then add alittle race fuel to my tank and it goes away. Preignition can kill a perfectly good motor real quick, so stay out of the throttle if you hear it. It can burn holes in the top of pistons, look it up i am sure there is tuns of info on preigniton on the board. Hope this helps.
Old Dec 29, 2009 | 01:58 PM
how can i check if my motor is affected?
Wearin' da big hat
I'd be a little concerned about that man
Old Dec 29, 2009 | 02:08 PM
JAVI05's Avatar
^^ no sh*t.. no ping no matter what.. not good.. op- maybe u got some sand in your intake.. lol... j/k...
