Where to get a custom serp. belt made
Figure what length you want and check if the manufacturer makes something close.I wanted a Gatorback belt for my Magnacharger the Gates belt was a 6rib 112",Goodyear did't show that size but the did show a 111.5"belt 4061115.The lenth of the belt and number of ribs are in the part number,the Gates number for my 112" belt is KO61120.
I've got a fleet account with Autozone through my bussiness they did'nt stock the 4061120 the 4061115 fits 7.3liter Ford truck so they kept it in stock.I thought ProChargers used an 8 rib belt.
The truck kits use the 6 rib belt. I think some of the camaro kits come with an 8 rib setup. I actually have an extra 112 laying around as a backup. I got one from summit and the one I have on the truck right now I got from a local parts shop. They had to order it, but they had it in a day.
I had the same belt as whitt1 for my Radix system. I looked all around for the 112" gatorback with no luck. the longest I would find was a 110.5". It fit .. barely .. soon after that I was in the shop replacing my altenantor. I wouldn't get one too tight, but a half inch off shouldn't hurt anything.
I had to push the tensioner down all the way, and then scrape the ribs over the altenator pulley, so it you are trying them out .. that means it's tight.
GXPJAY
Feb 13, 2022 08:15 AM
Corvette454l88
Sep 1, 2016 01:24 AM
