Where do I find info on fan upgrade?
Old Mar 14, 2003 | 11:45 AM
GMC SS's Avatar
Default Where do I find info on fan upgrade?
I have seen reference to a dual electric fan upgrade for trucks. I have a 2000 Sierra 5.3. Where do I get more info on the parts required and the how to steps to install it?
Old Mar 14, 2003 | 06:06 PM
Texas Terminator's Avatar
11 Second Club
Default Re: Where do I find info on fan upgrade?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by whitt1:
<strong> I'm running the Flex-a-lite setup.All you do is remove the stock fan and shroud,then their's is a straight bolton.It's a good mod truck runs cooler,improved throttle response,and a slight improvement in performance.No downside except the cost. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">only if you have the 34" radiator. i have them and they work great even in the TX summer heat. you can also get some fans from an f-body and wire them in with a kit from autocrap, slowreiliey's, pep *****, or whoever your local parts supplier is.
Old Mar 14, 2003 | 07:48 PM
BlueSS's Avatar
I have sum off a 99 SS on my 00' 5.3 chevy they work awesome even when i'm down in texas... Go to any junkyard and get them off ne 93 + Camaro or Firebird makesure u get all the wiring... Good luck...
<small>[ March 14, 2003, 07:49 PM: Message edited by: BlueSS ]</small>
Old Mar 14, 2003 | 08:40 PM
GMC SS's Avatar
Thanks for the info. One last question. Since the OEM is belt driven and the new is electric, how does it hook into the OEM wiring so it comes on automatically?
Old Mar 15, 2003 | 12:05 AM
Old Mar 15, 2003 | 11:14 AM
CashDudeHomie's Avatar
You use a relay kit. I ran the trip wire into the fuse box and stuck it in with the IGN E fuse. Also be sure to use a fuse on the power wire running to each fan and ground them to the cross member right below the crank pulley.
Old Mar 15, 2003 | 07:42 PM
GMC SS's Avatar
Thanks for the help. I am off to local yard in search for a fan.
Oobray
Jun 13, 2022 03:38 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
gtyler04
Jul 28, 2015 06:21 PM
