When will OBX's be not enough?
Old Oct 29, 2010 | 10:30 AM
mhotrodscooter's Avatar
Default When will OBX's be not enough?
I found out a couple weeks ago, how much my exhaust was holding me back.. Now I wonder if my OBX's or 2.. Guess I don't know how for I can go with them.. I'm looking for 400rwhp, the calculator says I'm close. So how much is everyone else making through OBX's? Before I drop a grand on some ARH's..
Old Oct 29, 2010 | 10:47 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
really?
Old Oct 29, 2010 | 10:53 AM
Really what?
Old Oct 29, 2010 | 11:05 AM
trever1t's Avatar
if i understand you correctly you're asking if one set of long tube headers is more efficient than another for a 400hp. application? I can't see how you're being held back?
I'm doing just fine with an old used welded up set of tube
Old Oct 29, 2010 | 11:15 AM
GMCtrk's Avatar
And your setup relates to his how? Superchargers don't gain much, if anything from longtubes.
IIRC, HirdleJ's 6.0 was held back by the OBX headers and he now has 1 7/8". I have 1 7/8s but I'm not sure how much they help, if anything over 1 3/4 on a h/c 6.0. I think it really comes down to how much you are willing to spend.
Old Oct 29, 2010 | 11:16 AM
Well ObX's has 2.5 collectors, I'm sure you know that.. I do plan on spraying, so I wonder if the OBX's will be enough.. If someone is making big power with them, I'll keep them.
Old Oct 29, 2010 | 11:30 AM
Was it the the tube size or the collector size? If seen a thread somewhere on a s/c vette, were tube sizes made no difference in hp
Old Oct 29, 2010 | 02:15 PM
Bigschwerm's Avatar
I have asked the same question before because I am about to do P/P 762 heads custom ground cam and TBSS intake on my 5.3l...and the answers i got were the collector size might be a hindrance... So i am going modify the y pipe to run 2.5" true duals and if thats doesnt get me 400rwhp i have a set of used LPP long tubes with 3" collectors i can get pretty cheap.
Hope that helps...Good luck with your build!
Old Oct 29, 2010 | 02:31 PM
Mangled03gmc's Avatar
Baltimore Whore
Your are more then good with that set up. Guys have been in the 11's no prob with 2.5 collectors and small primaries..
Old Oct 29, 2010 | 02:38 PM
GMCtrk's Avatar
Not N/A they haven't.
