Wheel hop???
Old Jun 19, 2002 | 01:18 PM
1 BAD GM's Avatar
Default Wheel hop???
How many of you guys out there have wheel hop? I picked up quite a bit of wheel hop after I installed my converter.
What do ya'll think will be the best way to get rid of it?
Old Jun 19, 2002 | 01:31 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Wheel hop???
Try adjusting the tire pressures. 24-30 psi in the rears.
If that doesn't help, some sort of traction bars that tie into the frame from the axle.
Tony
Old Jun 19, 2002 | 02:33 PM
You really need to invest in a traction bar. Or take off the front sway bar and put the cheapest rear shock you can find on the rear which will be softer than the stock shocks which will give you more squat in the rear.
________
HOTELS IN MEXICO
Old Jun 19, 2002 | 02:51 PM
1 BAD GM's Avatar
Well, my truck is lowered, so there really is no way of changing up the shocks, and I love the handling, so there is definitely no way I will remove the front sway bar. I am looking maybe getting some CalTrac traction bars. But I am going to lower the air pressure in my tires some first.
Old Jun 19, 2002 | 03:31 PM
oxidizr's Avatar
Moderator / Sponsor
<img src="http://home.earthlink.net/~rwaitas/_uimages/CalTracsSide.JPG" alt=" - " />
<img src="http://home.earthlink.net/~rwaitas/_uimages/CalTracsRear.JPG" alt=" - " />
These will help tremendously.
Richard
Old Jun 19, 2002 | 03:43 PM
96-speed's Avatar
Go to Home Depot and buy some cement bags.
Or, have a friend drive and make you sit in the bed, since you are ugly and have a big gut.
Either way your problem has been solved!
Ryan <img border="0" alt="[angel]" title="" src="graemlins/gr_angel.gif" />
<img border="0" alt="[Truck]" title="" src="graemlins/gr_truck.gif" />
Old Jun 19, 2002 | 03:54 PM
1 BAD GM's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 96-speed:
<strong>Go to Home Depot and buy some cement bags.
<img border="0" alt="[Truck]" title="" src="graemlins/gr_truck.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">LOL!!! ***!
Maybe I should just load your fat butt in the bed of my truck! But then I wouldn't have to worry about wheel hop because I would have no pick up at all with the load I'd be carrying.
Atleast I don't worry about my truck breaking at the track and having a really expensive tow bill to get it back home. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ June 19, 2002, 04:28 PM: Message edited by: Y2K2Sierra ]</small>
Old Jun 19, 2002 | 03:58 PM
That was funny comment...cement or your *** in the back...lol
________
HOW TO USE AN IOLITE VAPORIZER
Old Jun 19, 2002 | 07:52 PM
Vortech5300's Avatar
Cal Tracs like Oxider is showing in the pic. Those ******* properly set up RULE for traction. Those or South Side Machine bars but I am not sure if they make em for the trucks. Gonna be hard to solve it on a lowered truck, not enough weight transfer to the rear. You could also follow Hyde's advice and put some drag shocks on it and ditch the sway bar but it will handle like **** on the street. If it was me, I would just put on a set of Cal Tracs and run some GOOD DOT tires at the strip, like ET Streets. That should let it hook.
Old Jun 20, 2002 | 02:43 PM
96-speed's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Y2K2Sierra:
<strong>Maybe I should just load your fat butt in the bed of my truck! But then I wouldn't have to worry about wheel hop because I would have no pick up at all with the load I'd be carrying.
Atleast I don't worry about my truck breaking at the track and having a really expensive tow bill to get it back home. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Play nice! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" />
Ryan
