whats a stock for LQ4 worth complete motor?
To add to the OP I picked up an LQ9 that I switched to a LQ4. I put new rings, New cam bearings, New main bearings, New rod bearings, and new head gaskets on it. I plan to sell it for 900.
It's basically a long block. No intake but has all covers and oil pan. Seems fair to me and the buyer considering he don't have to put new stuff in it. If you go to the junkyard and get one for a lil less then you should still go through it and put new bearings in IMO cuz you don't know anything about how the engine was treated.
formerly 2low4nd (11-08-2011)
He took the offer, heres what it is now. Complete bottem end put together with the piston and rods, rings, bearings, cut crank, i pick a cam and everything is installed ready to go bottem end. Im very happy.
It would be a waste of money considering you can get a low mileage one for a fraction of the price.
Just doesn't make sense to pay that kind of money for a stock engine that you want to mod. For that kind of money you can buy a built shortblock from texas speed if you don't want to work on the engine yourself.
I've got a LSXrt manifold with a 102 mm tb that's givin me fits, cause I can't get it to fit right, I got a brand new Comp cam custom grind .226/.230 .598/.600 113+2 that I want to put in it, I got the heads milled, I got new LS7 lifters, I have a new 34" radiator and dual 16" flexalite fans to put on and I still have just a 5.3 with 135,000 miles on it. I've been getting into hunting deer, and I might need to get a small camper. There's no way I can pull a camper with that cam and a 3600 stall converter, but that intake on a stock 6.0 and a stock converter with a 4.10 rear and a built tranny will pull the **** out of a camper. And it's definitely cheaper than a new truck.
The engines that Texas speed have would be a short block. Just take your lifters, cam and everything and put it in one from them rather than a new stock engine for the same price. Just seems you'd get the most out of your money that way. That way you are getting the 0 mileage engine you want and the stronger internals in case you decide you want more power later.
4k for a stock Lq4/Lq9 is wasteful spending when you can spend 3500-4k for a built 370 short block and grab some $200 317 heads to put on it and throw your mods on it and be far better off. You'd have a much more reliable engine that way.
Just food for thought. Didn't want to see anyone waste money like that just to get something with no miles.
