What's the single best mod for a 5.3?
Old Jan 31, 2005 | 08:12 PM
  #31
litreddevil's Avatar
Banned
Originally Posted by deano
I just bought a completely stock '02 Sierra extended cab 5.3 2WD. I will be using it to tow my race car this year on an aluminum open trailer with a large storage box (car and trailer weight about 4500lbs.). Most of the tracks I will be going to are about 400 miles from my house.
I don't have a lot of money to spend on the truck, but I'd like to do at least one thing to improve the power and/or mileage that the truck will get. What are some of the single best modifications that I can do to this truck to improve power and/or fuel mileage?
GET A CUSTOM TUNE AND THEN LATER U CAN BUILD ON THAT CUSTOM TUNE,EXHAUST,COLD AIR U CAN MAKE THIS YOUR SELF FOR ABOUT 60.00 WITH K&N,& E-FANS WILL ALSO HELP ALOT IT IS TAKEN WAY FROM WHAT THE MOTOR IS TURNING.GO TO www.thunderracing .com THEY CAN DO CUSTOM TUNES AND GEOFF IS REALLY GOOD DOING IT DID MINE AND THEN WE DYNO IT ONLY COULD GET 10 MORE HPS ON DYNO ARE CALL 1-225-754-7223.TALK TO PAUL, ARE DAVID
Old Jan 31, 2005 | 08:23 PM
  #32
Mr. Sandog's Avatar
The cam in my sig made a 15-20 RWHP increase in power across the band, but better than that, changed my truck's driving characteristics for the better. I have much more power right off idle than I did with the stock cam, all the way through redline. And though a tune would certainly help, it's by no means required with a cam this mild.
If you're going to tow, I would be leery of any aftermarket converter (with the possible exception of the TT2600). But that's just me. Good luck with your decision.
Old Jan 31, 2005 | 08:25 PM
  #33
BADMOFO's Avatar
Cuz I AM a BADMOFO
For the $700-$800 you were talking about spending I'd get a USED Hypertech HppIII and a Yank TT3000 converter. That should absorb the total $700-$800 and give the best bang for the buck. A custom tune might be better, but a lot of the custom tune gain is made by removing TQ management, and I'm not a big fan of that, as most who do it end up not only removing TQ management but also replacing their transmission. The reason I say get a used Hypertech is because if you don't like it (but you will) you can resell it here or on Ebay and get your money back. The Yank converter really does make the truck fun to drive, and its really not as "extreme" as you would think. Where are you located? You might find someone "local" to you who would be willing to take you for a spin in their truck with converter. If you're close to Baltimore you're welcome to go for a ride in mine! Welcome to the site, and a warning, this **** can be addictive!
Old Jan 31, 2005 | 09:39 PM
  #34
parish8's Avatar
single digit dreamer
i am with this guy. i towed with my tt3000 many times it was about a 3000lb enclosed trailer and i took it thru the mountains a couple of times even. an open car trailer is a little heavier but with no 7'x8' wall of steel it is probably less strain on the truck to tow. most of the gains from a tune will come in shift points and rev limiter anyways.
Old Feb 1, 2005 | 04:50 PM
  #35
sexyvic1's Avatar
how much hp do u get from a tune? and by tune do u mean the programers?
Old Feb 1, 2005 | 05:10 PM
  #36
Gordy M's Avatar
I use my Yukon for towing (over 36000 miles of towing so far). Best mods for the money are Thorley Headers, great for low and mid torque and Corvette servo for 1-2 shifts and downshifts and billit OD servo for crusing down the Highway without constant shifting from OD. Also increased gas milage about 0.5 mpg towing and almost 1 mpg otherwise. Headers $450, servo's $15 and $70.
Old Feb 1, 2005 | 08:11 PM
  #37
sfj
another vote for TC or a tune i also recommend a nelson tune (way to go allen!!!!)
Old Feb 1, 2005 | 08:34 PM
  #38
jmproductions's Avatar
For his needs: My vote goes for a muffler change and then a tune. Maybe a custom electric fan conversion, if he is thrifty. That should get him a little more power but also bring up the mileage as much as possible.
Old Feb 1, 2005 | 11:07 PM
  #39
nightmarechevy's Avatar
Radix
Old Feb 2, 2005 | 08:08 AM
  #40
Elec. Fans! = 11 WHP & 2-3 MPG
