whats the best way to clean pistons???
Yessir...
as for the sandblasting, I believe that most machine shops have glass bead booths that are not as harsh on aluminum products...I glass beaded many cylinder heads at my father's shop back in the day, but can't remember if I ever did any pistons...
That little nick on the edge of the piston is nothing at all to worry about. If you're worried about that little thing disturbing the integrity of the piston, then you should also be worried about the numbers that were stamped into the tops of the pistons. Well, you really just shouldn't worry about any of that. It won't affect anything. In fact, many piston manufacturers dimple or notch one edge of the piston at the top edge to tell the builder which end of the piston should face the front of the engine. Clean em up & put em in!! If you're putting used pistons in your build, then it's a "budget build" anyways, not an "all out" build.
91LT16SpeedFormula
Oct 17, 2015 08:01 PM
gmcyukon
Oct 3, 2015 11:03 PM
Closer_2001
Sep 24, 2015 09:15 PM
