Whats the best exhaust manifold gasket
Old Mar 6, 2012 | 12:34 PM
2000chevysilverado's Avatar
Default Whats the best exhaust manifold gasket
Well came to the conclusion that I have a bad manifold and its not leaking by the broken manifold bolt, so I will be buying a set of long tubes and the best exhaust manifold gaskets, I did a search and percys header gaskets look to be the best is that true or you guys know anything better
Old Mar 6, 2012 | 12:43 PM
TXsilverado's Avatar
the best gasket is the stock gasket. i have re-used mine 10-12 times and they still seal perfectly.
Old Mar 6, 2012 | 12:50 PM
My stock ones are not sealing up at all end up changing them with a set of felpros still leaked i looked again at the felpros and can tell it leaking on cylinders 3 5 and 7 on bottom side of each cylinder, cylinder 1 is not leaking and that has the broken manifold bolt
Old Mar 6, 2012 | 02:08 PM
try a new set of OEM gaskets. that's what everyone on the forum uses.
Old Mar 6, 2012 | 08:19 PM
06Sierra2's Avatar
im running the percy's....
Old Mar 7, 2012 | 05:09 PM
DTHPROOF's Avatar
New GM MLS ftw, imho. ~$25 , you can't beat them.
Old Mar 7, 2012 | 05:19 PM
You got a part number and or website to pick them up
Old Mar 7, 2012 | 07:07 PM
DTHPROOF's Avatar
I don't off-hand. I ordered my last set from the local dealership. Sdparts.com may have them.
Old Mar 7, 2012 | 07:08 PM
Alright I will do that thanks
Old Mar 7, 2012 | 07:22 PM
01silvy's Avatar
Stock mls gaskets are hard to beat.
