what are your na 5.3 numbers?
Old Mar 14, 2005 | 08:29 PM
  #31
12sec.5.3's Avatar
Dyno #'s- 331hp/325tq
Best e.t- 12.81@103.5
Mods in sig.
Old Mar 14, 2005 | 09:10 PM
  #32
tooquick2beslo's Avatar
Originally Posted by BigKID
Dyno: 320hp/331tq on a DynoJet (3rd gear pull)
Track: 13.17@102.18
Mods: FMS 214/216 cam, self ported heads, self tunned w/Edit, Hamm Headers, True dual 2.5" exhaust w/Magnaflows, Yank TT3000, Homemade 4" CIA, 34" radiator w/dual Zirgo 16" fans, ASP pullies, 26x11.50x16 ET Streets(track only), other small misc. stuff.
What size rearend do you have ? 3.42? 4.10 ?
Originally Posted by v8
282hp 304tq, shorty headers, stock exhaust with a edelbrock muffler,elect. fans,asp pulley,cold air intake,bbk t/b,tuneing,3.42 gears with an eaton posi,2300 stall converter,transgo shift kit, thats it lol
hope to see better #'s on the 30th of april. changes the tail pipes alittle.
times 13.67 at 97.91mph
cam 198 207 500 500 115.5 and the tornado.
How much does your truck weigh ?
Old Mar 14, 2005 | 09:45 PM
  #33
02sierraz71_5.3's Avatar
Track: 13.17@102.18
Id like to hear more about this setup, tell us about the porting on the heads what did you use and what area did you focus on? Did you have them flowed? Any milling or valve work (angle job, cutback)?
Homemade CIA: what did you use materials wise, are you still using stock box whats the setup
cam: whats the lift on the cam, lsa, springs, what rpm are you shifting
Old Mar 14, 2005 | 09:47 PM
  #34
Originally Posted by 02denali
oh yay here is a pic of my dyno sheet.
http://img.photobucket.com/albums/v1.../lastscan1.jpg
thats a nice curve lots of area im jealous
Old Mar 15, 2005 | 10:47 AM
  #35
BigKID's Avatar
Tib.. I cut a 1.85 60' on that pass which is about my average short time on motor.
Tooquick... I still have the stock 3.73 gears that came in the truck with the addition of an eaton posi after the G80 gave up the ghost.
02Sierra... I answered most all of your questions already in either pm or in an open forum but I will answer them again here. Check this thread started by you for the specifics on what I did to the heads. https://ls1tech.com/forums/showthrea...t=ported+heads
In addition to that I had them milled .040 and did not have any valve work done, which in retrospect, I wish I had. I did have them flowed but only after the porting and it was on an old superflow bench. Although I told them what bore to use, I dont know what bore they actually flowed them with so I dont think they are all that accurate.
Parts for CAI.. rubber 90* elbow, 4" al tubing and ss clamps from airflow online, 1/16" al sheet for heat shield from Lowes, 5x9" open element K&N from Advanced Autoparts, reused some stock pieces to attach the maf.
Cam specs are 214/216 .535/.545 113+4, comp 918 springs shifting out at 6200rpm.
Old Mar 15, 2005 | 11:35 AM
  #36
BLACKND's Avatar
2004 1500 Crew Cab.
Mods in sig, on DynoJet. 279 RWHP/314 RWTQ.
14.762@90.56 mph-----On Street Tires
2.214 60'
ASM headers this Friday, and Comp Cams 216/220 @ 114LSA in a few weeks.
Old Mar 15, 2005 | 06:00 PM
  #37
Quikenuf's Avatar
340.9 HP and 338.1 FT. lbs Cam only. times in sig. heres a link to dyno graph
http://thunderracing.com/dynographs/...n=read&pgid=94
Old Mar 15, 2005 | 06:59 PM
  #38
02Reaper's Avatar
Heads and cam 5.3 with bolt-ons
Old Mar 15, 2005 | 07:00 PM
  #39
v8
17,16,15,14,13,12,11 Drvr
tooquick2beslo my truck that night weighed in at 4450 lbs or real close to it 5/8 tank of gas no tail gate, spare or jack tools.
Old Mar 15, 2005 | 09:57 PM
  #40
Kano's Avatar
holy ****
how bout some details
