What is wrong with my pickup?!
Old May 13, 2010 | 12:42 PM
chevy_man2000's Avatar
yes i got it used and no i didn't hear it run
Old May 13, 2010 | 12:44 PM
but i stripped it down and checked all the internals and they looked good
Old May 13, 2010 | 12:48 PM
00ChevyScott's Avatar
Wearin' da big hat
Time for a compression test.
What do the spark plugs on the "dead" side look like? Is it just spewing out raw gas on that side or is it attempting to combust?
Old May 14, 2010 | 09:26 PM
eallanboggs's Avatar
Would ALL 4 cylinders on one Bank only lose compression while the other side is good? Not likely. The coil pack assemblies are an easy Bank to Bank swap on the GenIII. You can see the injector and ignition primary pulses using a low current clamp on probe like the CA-60 connected to your DVOM. You can also watch the secondary spark output using an adjustable spark checker. Look at wiring harnesses, connectors and their pins, etc.
dsbodley
Nov 14, 2015 09:46 PM
turbo6c3
Oct 5, 2015 06:11 PM
carid
Oct 1, 2015 09:22 AM
Mr. Chainsaw
Sep 24, 2015 09:45 PM
jamesm32
Sep 24, 2015 11:49 AM
