What stainless headers w/cats for 04 Silvy?
Old Feb 18, 2015 | 04:25 PM
Chiphead's Avatar
Default What stainless headers w/cats for 04 Silvy?
OK, I'm afraid this is another "what LT header" thread. The difference is this- I want stainless headers and a catted Y-pipe. 04 ECSB 2WD. I'm planning on having a muffler shop do the header install and I know they won't delete the cats. I don't care if I buy a pre-made catted Y or I have these local guys fab one up. I do want something that fits right.
So does anybody have suggestions for stainless headers that work with a catted Y? Under truck pics would be great, because I don't understand how the cats will fit behind LT header flanges. Seems tight ahead of the tranny X-member.
Engine will be a rebuilt 5.3 with 10:1 comp, 241s and mild cam.
Old Feb 19, 2015 | 11:14 AM
53bowtie's Avatar
American Racing Headers are probably the best fitting stainless with catted Y but they are also about the most expensive too. Look them up to see pics of how the cats will fit with their system.
It would be hard to fit universal cats behind the headers and before the trans cross member for sure, especially if you go with 3" pipe to build the Y.
You could do what I plan on doing and run a cat-less Y then run a single cat where the Y comes together and go into the muffler after the cat. This way there is more room and you can always have a "test pipe" made to replace the cat on days you want to go to the track.
Edit: Just saw a set of Kooks LT's and catted Y for sale in the Classified section. May want to check them out as well.....
Old Feb 20, 2015 | 11:26 AM
Chiphead's Avatar
Do most guys with headers run a ORY? I guess if you're not in cali or NY you just chuck the converters and have the back 02s tuned out?
Old Feb 20, 2015 | 12:17 PM
ezdaar's Avatar
Yup thats what we do
Old Feb 20, 2015 | 12:18 PM
53bowtie's Avatar
In Texas they are supposed to do a "visual inspection" for cats I believe but on OBDII vehicles as long as the check engine light is not on your good. So, yes, most people run an ORY or they will have a test pipe they can run and put the cat in for inspection.
Old Feb 20, 2015 | 02:23 PM
726.0chevelle's Avatar
13 Second Truck Club
Just be warned about the el cheapo ebay headers. They work and fit ok but they suck when it comes to the small stuff. Such as O2 bungs in the wrong spots connections not fitting tight odd ball donut gasket size the list goes on...
Old Feb 20, 2015 | 02:46 PM
ezdaar's Avatar
Even some of the mid level headers have these problems.
Stainless Works
Apr 10, 2016 04:34 PM
Stainless Works
13
Nov 5, 2015 03:31 PM
Stainless Works
Aug 7, 2015 10:08 AM
Stainless Works
Aug 4, 2015 12:56 PM
Ketis
Jul 23, 2015 12:37 PM
