What spark plugs with N20
NGK TR55s are good for small jettings 35-75 HP but can be used for higher if properly gapped and frequently checked upon (gap 0.038-0.045.)
Autolite 5245s are good for the lower HP settings as well an are a good standard cooper core plug.
NGK TR6s are good for much larger jettings 100-150 HP but again can be used for higher when properly gapped and maintained (gap 0.035-0.040.)
If you are running stock coils and such the TR6 with smaller gaps may cause po300 MMF codes to happen on occasion when driving NA.
Just remember to use a non-platinum plug, get a plug with a gap nearest your desired operating gap (need the least amount of adjustment) and check them frequently to insure you are operating in the correct heat range and gap.
