what size exhaust pipe will fit over the axle on a 4-5" drop?
Originally Posted by FogleMotorsports
i had 3'' exiting the stock location with a 4'' drop in the rear.
yea thats how i have mine and its fine... it just bends up and over the axle... ill try and get a pic for u
Originally Posted by LoudAzzLoStepside
Tin Foil Hat Wearin' Fool
Run dual 3" up and over the axle tucked up nice and close to the bed may heat the bottom of the bed bad but atleast you can keep your exhaust the way you like it. You can make some bumpstops to keep the rear axle from crushing your exhaust if need be. Just measure the distance you have between the axle and the bumpstop and the from teh axle to the pipe and you will know if you are going to have a problem wit h clearance issues or not.
