What to rebuild on 799 heads??
Old Aug 5, 2013 | 01:53 PM
2500HDKartRacer's Avatar
Default What to rebuild on 799 heads??
I've got a used set of 799 cylinder head coming to me. I plan on putting them on my 6.0L LQ4.
What do I need to replace on the heads?
Do I have to take them to a machine shop to be checked out? If so, what do I want them to check?
I plan on putting new LS6 springs on the heads and new valve seals. What valve seals are recommended?
Old Aug 5, 2013 | 04:20 PM
Beatdown Z's Avatar
Laid Back
How many miles are on the heads?
You could have them checked for flatness, then milled if they're not flat. You could also have them pressure tested and have the valve guide clearance checked.
Old Aug 5, 2013 | 04:53 PM
Ferocity02's Avatar
How many miles on them? If it's not much you can probably just run them.
Or send them to WCCH and have them check for flatness, valve seats, guides, stem height, etc. Go with OEM valve seals.
fullboardmax
Aug 6, 2015 01:35 PM
bobfig
Jul 25, 2015 04:42 PM
low2001gmc
Jul 23, 2015 05:10 PM
Ammadien
Jul 22, 2015 08:50 PM
