What plug wires are these? Confused.
Ok. So.
On the Left we have the MSD LSX plug wires part number 32819 (car)
2nd from the left we have the MSD LSX truck wires part number 32829
In the middle is a stock wire of an 03-04 6.0 truck motor
On the far right is the stock wire that came on my 09 6.2 L92
What gives? I was trying to run some new wires on it but everything I look at is different lengths and angles. Trying to find some shaped and link like the stock wires with that nice 90 degree bend in it. They fit really well.
Then when I checked the 6.0 truck motor it's wires were different as well. Wtf?
Depends on your coils. The difference in the coils requires different length wires. I know for the fact that the 90* wires don't work with stock square truck coils. I tried some Taylor 90* GTO wires and they were at least a 1/2" too short to even connect. Probably needed another 1-1.5" to be comfortable and not stretching. But they should work with the round truck coils.
Currently I have Mis matched coils. I have these which I will be finding a matching set for at some point.
And I have these which came on it and am running them just until I get some to match the other side.
What do the 90 degree wires come on originally? And does MSD make a 90 degree wire? Everything I see from MSD is straight with no 90's
I could not find 90 deg wires from MSD, so I went with Taylor. I got GTO wires based on this thread: https://www.performancetrucks.net/fo...-wires-474733/
THANK YOU! For that thread! Was able to find the Ac delco part number and use that to find these. They are about an inch longer but still have the 90. And they are like 50 bucks.
Tydriver
45
Oct 23, 2015 09:19 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
