What are my throttle body and maf options
Old Jul 24, 2011 | 03:15 PM
hotrodolds's Avatar
Default What are my throttle body and maf options
In the process of swapping a LQ4 into a 72 olds. I need a cable driven throttle body and a MAF. What is the best cable driven option out there? Stock LS1 TB and MAF.
Do the TBSS have larger MAFs would this be a worthwhile swap? At what point are aftermarket pieces the best way to go. Currently itll be stock with a tune and headers plus emmisions stuff deleted. Down the line in a year-ish i hope to do l92s and a large cam.
Old Jul 24, 2011 | 03:54 PM
AJII's Avatar
Only stock DBC throttle bodys are 78mm. Have to go aftermarket to get larger.
Stock TBSS is 87mm, but you'd need the tac module and throttle pedal and a newer PCM.
Old Jul 24, 2011 | 05:50 PM
hotrodolds's Avatar
What is the largest aftermarket the stock manifold can accept. A FAST LSXRT just is not in the cards nor do i expect it will be for a very long time.
Old Jul 24, 2011 | 06:03 PM
AJII's Avatar
Stock manifold only accepts 78mm. Can buy TBSS intake and 90mm DBC throttle body.
Old Jul 24, 2011 | 06:39 PM
swift700's Avatar
You would like the Holley.
Old Jul 24, 2011 | 06:59 PM
hotrodolds's Avatar
Thanks
Sometimes it seems like the simplest stuff is the hardest stuff to find when trying to use the search option
jdb11386
Dec 3, 2015 09:34 PM
smokeshow
Aug 23, 2015 08:23 PM
noproblems209
Aug 10, 2015 06:57 PM
GreyChevy
Jul 7, 2015 08:57 PM
Gadgetized
Jul 7, 2015 04:40 PM
