What to lubricate underneath truck?
Old Jul 20, 2006 | 05:20 PM
14 Second Truck Club
Default What to lubricate underneath truck?
Are there any grease fittings or things that need lubricating under the truck that I need to know about?
Thanks
Old Jul 20, 2006 | 05:22 PM
Thanks
My 05 VHO has 11-12 grease fittings total.
It depends on thr type of truck you have.
On your 99', you should have 2-upper balljoints, 2-lower balljoints, and 2 outer tie rod ends to grease.
You should also have one grease fitting on your driveshaft (in the middle) if you have a two piece driveshaft.
Jim
Old Jul 20, 2006 | 06:03 PM
Dang, didn't know all that, never really looked. Just got done greasing up my 4-wheeler and thought about it. Thanks for the info!
Old Jul 20, 2006 | 06:18 PM
YUKONTURTLE's Avatar
Thanks
This might help
Old Jul 20, 2006 | 06:27 PM
The front end of his truck isn't like the Tahoe, Suburban, Avalanche, Vortec Max, or SS trucks or SUV's.
His truck has a rack and pinion type steering system.
The most he will have to grease in the front is 6 grease fittings. A two piece driveshaft will have a grease fitting in the middle making a total of 7 grease fittings.
The other vehicles listed above will have 11 grease fittings in the front.
Mine has a total of 12 grease fitting due to the one on the driveshaft.
Jim
Old Jul 22, 2006 | 07:36 AM
I was able to reach 4 of the grease fittings. I wiped them off real good with a few paper towels and it was like the grease wasn't even going in. It was a good seal, I wonder if it was somehow clogged up or something.
BTW, where is the grease fitting on the split driveshaft? I looked and couldn't find anything.
Old Jul 22, 2006 | 06:50 PM
Post
Hmmm, I'm not sure if the older trucks have this grease fitting.
If it's there it will be located in the middle at the slip joint where the two driveshaft sections meet close to the carrier bearing. It will be on the last driveshaft section, not the first one.
Jim
wrb002
Aug 31, 2015 12:00 PM
Ketis
Jul 23, 2015 12:37 PM
Suburban2500
Jul 19, 2015 04:50 PM
black6spdz
Jul 16, 2015 01:32 AM
Nimoryan
Jul 5, 2015 03:50 PM
