What LSA to go with
Old May 14, 2009 | 01:09 PM
Mangled03gmc's Avatar
Baltimore Whore
Negative a tigher lsa angle such as a 112 will make more peak hp vs one with a wider lsa 116, which will have a broader range.. Thats why guys that run tight lsa usually have a higher stall....
Old May 14, 2009 | 01:10 PM
GMCtrk's Avatar
lower LSA will produce more peak power. Overlap = power. But the more overlap also the more difficult to tune. I'd go with 220/220 112 LSA 108 ICL for your setup
Old May 14, 2009 | 01:18 PM
Baltimore Whore
So you don't get guys confused here, lower as in the the number?? Some people refer to it differently
Old May 14, 2009 | 01:19 PM
GMCtrk's Avatar
you idiot. Do you know the meaning of the word lower?
Old May 14, 2009 | 01:27 PM
GMCtrk's Avatar
Baltimore Whore
Yah but depending on how the *** you mean lower.. Some guys use the word lower, but meaning a higher actual cam lsa 118.. A lower number lsa 112 is a Tighter cam... You skank
Old May 18, 2009 | 09:39 PM
2001CamaroGuy's Avatar
Lower/tighter (as in smaller numbered) LSA will produce more of HP peak in a narrower band. This works well for close ratio trans/high (numerical) geared rearend setups since they can remain in the "sweet spot" better. They tend to idle harsher since more dynamic compression is bleed off (later intake valve closing) at idle (thus the need for tuning and converters).
Higher/wider (as in larger numbered) LSA will produce a flatter HP curve. This works well for wider trans/lower geared rearends that have to operate over a wider band. They tend to idle better since the intake valve closes earlier and keeps dynamic compression higher.
wickedRCSB
Oct 10, 2015 09:29 PM
shootermwc
Oct 8, 2015 01:45 PM
Jake75
Oct 2, 2015 02:28 PM
dirt track racer 81
Sep 21, 2015 06:44 PM
