What is involved in a LS6 manifold swap?
Old Jan 7, 2006 | 07:06 AM
  #31
mattrem's Avatar
BigTex said someone on here did the swap. gained about 20-30 hp and shaved a few tenths of his ET. I think it might be a option. I am getting my cousins truck over here today and I am going to use it to mock up another manifold. Then I can really see what it involves.
Old Jan 8, 2006 | 09:59 PM
  #32
BigTex's Avatar
From a thread 3 years ago:
Originally Posted by Yelo
I did a swap from a truck intake to an LS1 intake and I saw NO difference in performance below 4500rpms...above that the airflow was greatly improved and the truck pulled MUCH harder to 5500....the only reason I swapped back is because I don't have f-body injectors yet and the ls1 intake with truck injectors and modified truck fuel rails kinda looked stupid....and the alternator bracket with the relocated idler pulley was kinda hacked together (I don't have a MIG welder so I had to bolt the new plate into place and I didn't like the look of it)
the reason I mentioned my swap is because the reason people swap from LS1 intakes tio LS6 intakes is to gain the high-end airflow that the LS6 intake is capable of.....unless you are going to put a cam in to take advantage of the airflow stick with the truck intake....it'll flow all you can use for normal driving
Originally Posted by blacksheep
{after LS6 intake install}... As for performance gains my truck was running 12.8 at 104 before and then 12.3 at 108 after. My truck pulls very hard on the top end now, but that may because the cam I'm running and also shift points. ...
Only changes were the intake and a short belt.
... My old 6.0 made 415rwhp N/A.
Old Jan 8, 2006 | 10:10 PM
  #33
BigTex's Avatar
Originally Posted by L33Z71
... There was a guy here in houston that took his 6.0 Escalade to HPE I think and got the FAST intake done with nitrous.
That was a friends escalade. I took it apart this past spring and sold it at auction. I sold the manifold conversion bracket and misc parts to redaddiction this past summer. I still have the FAST manifold and direct port system sitting in my garage on a shelf. Anyone want a direct port setup?
Old Jan 8, 2006 | 11:52 PM
  #34
Yelo's Avatar
YES....depending on what kind of $$$ you're looking for
Old Jan 9, 2006 | 06:19 AM
  #35
mattrem's Avatar
Who made the conversion bracket for the idler pulley?
Old Jan 9, 2006 | 06:21 AM
  #36
tdrumm's Avatar
Speartech make the idler relocation bracket.
Old Jan 9, 2006 | 12:36 PM
  #37
FlaBouy's Avatar
Originally Posted by tdrumm
I tend to agree with you, but the road block is there is no 90mm drive by wire throttle body option until we find out if the SDPC harness is a reality.
Could have swore Nick Williams made an ECT 90mm Throttle Body. Could be wrong though....
Old Jan 9, 2006 | 12:49 PM
  #38
BigTex's Avatar
Nick Williams does make a 90mm TB for the corvette guys. Problem is the internal sensors on the corvette aren't the same as the truck sensors. Same thing with the LS2 throttle bodys.
I didn't really like the location of the speartech idler bracket. It keeps the same belt routing which left the belt way too close to the throttle body for my tastes.
Old Jan 9, 2006 | 01:14 PM
  #39
FlaBouy's Avatar
[QUOTE=BigTex]Nick Williams does make a 90mm TB for the corvette guys. Problem is the internal sensors on the corvette aren't the same as the truck sensors. Same thing with the LS2 throttle bodys.
QUOTE]
Thanks for that tidbit. I am looking for an intake and TB setup for my blown 5.3L 2004 Avalanche I was looking at the the FAST intake. I guess the FAST intake and the BBK 80MM ECT TB is the hookup for this situation? Any alternatives?
Old Jan 9, 2006 | 04:57 PM
  #40
mattrem's Avatar
It there a different idler bracket I can use? Or is the speartech the only one?
