What happens when water pumps go bad?
#51
Originally Posted by thunder550
Tried that this afternoon, still nothing. There were no bubbles coming out of the coolant crossover pipe, it was all coolant. And really really hot
I also checked the upper hose from the passenger side of the radiator. I pulled the hose off the radiator and coolant started leaking out, so there's no air in the radiator either. I also put in a bleeder fitting on the heater hose going into the cabin, no air there either. Looks like this is just the way it is. I think I'll be investing in a twin core radiator sometime in the forseeable future.
#52
Originally Posted by RWC
I thought my radiator was clean too until I washed it out. The radiator shop said that was one of the biggest problems with these radiators because the fins are so close together they plug easy. BTW what efans did you have? The factory 05 fans that I added keep my truck under 200 degrees when pulling a 8000 lb tractor.
#53
Originally Posted by phasemaster1
When I did this the first time it was hot and didnt do anything ,thats when i removed the thermostat. When I got bubbles is when I let it cool to ambient temp like over night and I had installed the thermo back in. You might have to let it cool fully after warming it up...
#55
just something to throw out there, but has anyone tried that royal purple ice liquid for you radiator? I've heard people using it, but I havent seen anyone here try it yet?
#56
Originally Posted by el_cabby
so thunder did you ever get ur cooling system to work properly as you wanted?
#57
I have always drilled a small 1/8 hole in my thermastats in both my 2001 suburban and my 2005 Truck and never have had an issue with air in the system, they both have SLP 160deg stat's the 2005 has the factory E-fans and it always runs 178 to 180 cruising down the road even at 104deg outside temp and 185 max at Idle.
The 2001 Suburban has a clutch fan and it runs at 175 to 183 deg all the time.
BTW both are Supercharged, 2001 Magnason side mount, 2005 has a Radix.
#58
formerly 1BADC10 (12/14/2011)
After reading 6 pages, I don't remember seeing that the front end was lifted when refilling (just assuming you did that). May seem minute, but worth the suggestion. Also... it's been suggested to me to get the rad flushed (if all else fails). Who's to say that corrosion over time hasn't occured. Just flushing with a garden hose won't do the best job either.
#59
I was very careful to make sure there is no air trapped in the system. I'm 100% sure that's not the problem.
