what flows better?
Old Jul 27, 2006 | 01:41 PM
Default what flows better?
well ive gotten mixed feelings on what intake flows better between the truck intake and the ls1 car intake. i would like to know if anyone has any dyno numbers proving either way. if the ls1 intake doesnt flow any better then im not gonna make the swap, if it does then i can get one for $30. so post up guys.
Old Jul 27, 2006 | 03:38 PM
noone has any info on which of these intakes flow better?
Old Jul 27, 2006 | 03:51 PM
98vortecbw's Avatar
I have heard that the car intake doesnt flow enough to make the swap. But ls6 on the other hand would worth you while.
Old Jul 27, 2006 | 04:32 PM
well i dont have the money to get an ls6 intake and do the swap right now. it would cost at least $500 dollars to do that swap and i can do the ls1 swap for less than $150. but im not gonna waste my money if it aint worth it. thats why i would like to see some dyno sheets showing which one made more power.
Don't waste your time on the LS1. LS6 or better. Do a search. Someone posted results out of a magazine a while back. Had 4 or 5 different intakes tested with dyno numbers. And, with different tb also.
Old Jul 28, 2006 | 11:02 AM
Quik's Avatar
5 year bitches!
ls1 not worth the swap but to do the ls6 you better have a motor that can pull up high or its not woth the swap either. i run one but i also pull up top. if you have a little cam dont bother and stick with the truck setup. if you have a cam with duration above 226/228 then go ls6.
as for the swap theres two ways one is the bracket setup or the way i did and completely use fbody front accesories but this may cost the average person a fortune
Old Jul 28, 2006 | 03:02 PM
thats the kinda info im looking for. i just didnt want to go thru the trouble of changing everything if it wasnt gonna help. i do have p&p heads and a 224/228 114lsa cam. do you think thats enough to justify the ls1 intake, cuz i am not spending the money on the ls6.
Old Jul 28, 2006 | 03:07 PM
Quik's Avatar
5 year bitches!
truck intake> ls1
LS6> truck>ls1
90mm fast>ls6 only above 6k
so to answer your question no dont do it
Old Jul 28, 2006 | 03:21 PM
moregrip's Avatar
what a rush!
Richard from WCCH actually flow tested some of them:
https://www.performancetrucks.net/fo...d.php?t=361146
SloSVO
Nov 22, 2020 07:34 PM
madmann26
Apr 29, 2020 09:17 AM
OHsixLS3
Nov 22, 2015 07:45 PM
zblee
Nov 11, 2015 12:41 AM
Rockrz
Sep 29, 2015 09:07 AM
