What exactly is LS1 edit?
Is LS1 edit like a Hypertech3 or can you do much much more with this program? What is the price for the program? Does anyone have a link that shows some of what the program looks like and what it can do?
It is true software that connects to PCM via a cable to your computer. You download you current PCM to a file, then you can edit certain areas of your PCM with the program. Then upload the changes back to your PCM. It can do everything that hypertech can do, an much more that it cant. It does have a learning curve and can get you into trouble if you aren't careful.
$550 for fisrt PCM. It probably isn't a good choice unless you have a real "need" to change some settings that you cant get to with a hypertech.
FormulaZR
Sep 14, 2015 05:23 PM
brandon_6667
Sep 6, 2015 04:49 PM
