What do you think
Old Oct 5, 2010 | 08:55 PM
06pcklm7's Avatar
Default What do you think
I just got a call from a buddy who owns a salvage yard. He just pulled a 6.2L from a denali. Wants to sell just the motor PRETTY cheap I think.(throttle body to oil pan) I think. It has 15,000 miles on it and he want like 2500isshh. Now the big ???? can i put this in my 2006 rcsb 5.3L pickup, how much headache will this be? I plan on deleteing the vvt and installing a cam before i drop it in. Its sounds pretty awesome but is this Possible.. He says anythings possible which i kind of beleive, but Labor aint free.
Old Oct 5, 2010 | 09:57 PM
ramairroughneck's Avatar
You'll have to buy a box that converts the crank signal to one that is compatable with your pcm. Lingenfelter sells it for $255. $2500ish for the motor. To delete the vvt your going to need a new front engine cover, cam, valvesprings. Not for sure maybe a timing set and oil pump. Your up around a thousand right there. The combo will have to be tuned so another $500+. Tack on labor and your looking at a pretty hefty sum.
Old Oct 5, 2010 | 11:49 PM
06pcklm7's Avatar
yes your right. is that all I will have to get is the crank signal box from them? This thing will bolt up to a 4l65e? I know it has to be tuned also that's not a big deal. Might just leave the engine stock put a turbo on it.
Old Oct 6, 2010 | 01:25 AM
CHILLLLLL's Avatar
formerly Stroked-DSM (11/24/2010)
I'm not too familiar with the swap, but if they have pretty decent acceleration in an escalade the motor alone would probably haul *** in a RCSB
Old Oct 6, 2010 | 02:45 AM
matthew20061's Avatar
Yes it should all LS engines have the same bell housing bolt pattern.
Old Oct 6, 2010 | 07:31 AM
06pcklm7's Avatar
I really want to try this. I still have a little research to do. I think that thing should haul some a$$. Antone done this yet 6.2 in front of a 60e or 65e??
Old Oct 6, 2010 | 09:05 AM
Robert91RS's Avatar
Think of the 6.2 as an improved LS2. The LS2 was matched to 4L60/4L65s in corvettes, SSRs and TBSSs. Should be a easy swap but I will take one for the team and put it in my truck if you preffer
Old Oct 6, 2010 | 10:25 AM
06pcklm7's Avatar
Ha I hear ya. I do believe I have my mind set he drop the price a little today so I can't really pass it up. Does any know if my obx lts. Will bolt up
Old Oct 6, 2010 | 10:33 AM
baSICK5.0's Avatar
A guy I know has this swap in a 05 rcsb 4x4, cammed, stalled, sprayed... run mid 7's in the 1/8th. Runs 8.0 or better on motor
http://www.youtube.com/user/badmanls1
BTW what is the price? this guy copped his for $2,200 with like 4,000 miles on it. but they usually go for $4,000 +
baSICK5.0's Avatar
He got his box from lingenfelter i think
